pulling JD 50
Johnny50
I used to pull the JD 50 in the 5000# and 6000# classes but find I"m front heavy in the 5000# class with the tractor bare. Would it be better to weigh up to the 7000#? If so how much weight out front? I put 100# about a foot from the tin in the 6000#. would 200# be enough in the 7000# class out front? Any comments would be appreciated. By the way, I"m from way down East in Nova Scotia. We"re just getting started in this antique pulling.
Your 50 may not do very well at 7000lbs. It would be a better time at 5000 and 6000. Your front should not come up any more than an inch or two at the end of your pull. Make sure that your hitch is up the right height. the higher it is the more the oull down you get. too high in the front, and you loose the leverage on your tractor, and spin out. Put it in low gear and have all the fun you can!
we generally put 200lbs up front per 1000lbs class increase, so if you add 100lbs in the 6000lb class, maybe you should put 7000lbs up front
