Pulling Sled
BrianM3
Trying to figure out how to pull the box back on a sled that is not on a incline. Not sure how to do it with hydraulics so it will free spoil on the way up.
Mine uses a hydraulic motor. The valve on the motor is electric and is in float anytime power is not supplied to it. So while going down the track it lets the motor freewheel. As soon as I apply power to it through a switch it kicks on and runs the box back. Supply power the other way and it will run the box forward. Below is a link to the valve I believe I used. You would just need to order a subplate with it also to mount it on.
If you didn't want to use an electric valve then just order a manual valve that has a float position on it. Just don't forget to put it in float before they take off with the sled or it will tear something up.
http://www.northerntool.com/shop/tools/product_200329571_200329571
