john in la
I know the RPM of a motor and how fast I want the object to turn.
What is the math equation to figure what 2 pullies to use.
I would think it's a direct ratio of the circumference of the 2 pullies. Since the circumference is Pi x D, then you could ratio the diameters. Eg, if you want to reduce the speed by 1/2, then the motor pulley should have a diameter twice that of the item pulley.I know the RPM of a motor and how fast I want the object to turn.
A lot of good answers here.I know the RPM of a motor and how fast I want the object to turn.
You are correct in that.A lot of good answers here.
I accidentally learned something that I should have known - when experimenting with driven shaft speeds - if you add the pulley diameters together you can use the same belt as long as the sum of the pulley sizes stay the same. Example - A shop attic fan turned too slow to suit me. Pulleys were 7" and 2". I switched to 5" and 4" and the same belt fits perfectly.
That might involve more than two pulleys.Thanks for the help.
I am trying to achieve a driven shaft RPM of about 200 off an electric motor.
I have an old washing machine motor and a motor off an old air compressor to choose from but I have not looked at their RPM rating.
I am under the impression that torque goes up as RPM goes down.
If my calculations are correct a 1.5 inch drive pulley and a 13 inch pulley off a swamp cooler should get me in the right RPM range at a 1750 motor speed.That might involve more than two pulleys.
As "old" air compressor motors are usually no less than 1725rpm's.
The 1.5 drive pulley might not have enough belt contact to achieve what you are driving.If my calculations are correct a 1.5 inch drive pulley and a 13 inch pulley off a swamp cooler should get me in the right RPM range at a 1750 motor speed.
Now i need to check the motor specs for the motors I have.
My calculations concur.If my calculations are correct a 1.5 inch drive pulley and a 13 inch pulley off a swamp cooler should get me in the right RPM range at a 1750 motor speed.
HummmmThe 1.5 drive pulley might not have enough belt contact to achieve what you are driving.
Yep, https://www.omnicalculator.com/physics/belt-lengthEasy,.... pull-up a pulley calculator on the net.
With really small pulleys, you can incorporate an idler and longer belt to get as much 'wrap' on the small pulley as possible. Greatly increases the driving power if you can get a 180deg contact.Hummmm
That is something to think about.
2.5 and 14 would get me a little over 300 rpm
That might work
