Just read the post below, got me to wondering,I also have a Wagner loader with what is probably the original pump. What is the GPM flow through that pump? It leaks and I have a newer pump that I am thinking about replacing it with. Can I go to a higher GPM pump?
I don"t know what the pump you have is rated at but if you know the piston diameter and stroke, you can measure the time to stroke the cylider and calculate the pump flow rate.
Yes you can go to a higher displacemnt pump as long as it will deliver the pressure you need. It will speed up the loader and take more power, however.
A lot of loaders on the older farm tractors use a 8-10 GPM pump due to safety. A pump that puts out say 20 GPM can/will cause a loader to move a lot faster and that in turn causes flipped over tractors etc. I have 2 ford tractors that have vickers vane pumps on them and both with loaders and those 2 pumps are in the 8GPM range and many others I have worked on had the same pumps
Well, we don't know what make, or model, of
pump you have, so it's impossible to calculate
flow at any specific RPM....WHY ?
There is no "Wagner" brand or model of pump!
Wagner bought pumps from others, and there's no way of knowing what you have unless you have
some literature, or there's a tag, or casting
number on the exsisting pump.
