Pump loosing prime
dmbinva
I have a 640 that is giving me a fit. I have rebuilt the pump. You can bleed the pump and the loft will work. let the lift back down and you have to bleed the pump again.
David
there is an early model and a late model bearing mechanism associated with the nose/drive end of the hydraulic pump - the early style used a doubled ball bearing design and is prone to leaking air/losing prime -
the early style isn't serviced so if that's the problem you are looking at finding a different pump to deal with the issue -
