Pump Mounting plate
Phil Tibbetts
Will the pump mount plate from a TO 35 fit on a 205 industrial? The thread is stripped out on my 205 and I have a chance to get one from a TO 35 if it will work.
Maybe my question wasn't clear. I was looking for compatibility of the plate with the left hand thread that attaches to the crankshaft pulley for driving a loader pump. Can't seem to find info on it.
Hello
The the only difference I can see from the manual is the bolts which fasten the pulley adapter plate to the engine pulley. The TO35 with a gas engine used 7/16x 1 1/4 and the 205 uses 3/8 x 1 1/4 and .the left hand thread is the same 3/4-10.
The manual does mention that the MF35 utility tractor 203 and 205 use the pump drive but does not include the TO35 in the same chart.
The manual only provides dimensions in comparison tables and not actual part numbers for comparison purposes.
Well provided that the hole in the rubber bushing is the same size it would work. Possibly could make a bushing if it is bigger in the TO 35. Thanks for the info
