Royse
- Location
- Ionia County, Michigan
Would it have come with a double clutch, since it has the 5 speed transmission?
If you are wanting to be correct, where is the rest-o-ride seat? The air-precleaner was not a factory option
(quoted from post at 12:45:09 05/21/15)
I agree it's very nice but for that price it should be an 860 and have PS.
(quoted from post at 09:00:06 05/21/15)
The restorer knows his Fords! I can't pick out a single thing wrong with the finish. There is paint where it is supposed to be and not where it should not be. It even looks like the clamp holding the coil is black as it should be.
(quoted from post at 19:15:45 05/21/15) Dang if you guys are gona pick it apart.......
I do not see a battery hold down;
And what's up with that aftermarket oil filter.
(quoted from post at 12:14:10 05/21/15)(quoted from post at 09:00:06 05/21/15)
Wait.....coil clamp is supposed to be black? Darn it, I have that nice new plated thing on mine...
Weren't you leaving all the bolts au naturel too?(quoted from post at 15:14:10 05/21/15)(quoted from post at 09:00:06 05/21/15)
(quoted from post at 23:22:23 05/21/15)Weren't you leaving all the bolts au naturel too?(quoted from post at 15:14:10 05/21/15)(quoted from post at 09:00:06 05/21/15)
The clamp will probably add a nice accent.
(quoted from post at 05:30:39 05/22/15)(quoted from post at 23:22:23 05/21/15)Weren't you leaving all the bolts au naturel too?(quoted from post at 15:14:10 05/21/15)(quoted from post at 09:00:06 05/21/15)
Yeah, leaving most bolts natural. I'd like to think that I could figure out the assembly sequence (somewhat), which would dictate which hardware gets left unpainted. But I'm sure I got some stuff wrong. So I'll just say "I'm going for a detailed look" or something like that, LOL.
OK showcrop, is that thing supposed to be gloss, semi-gloss, or flat black? LOL If I paint it, I need to do it right.
Thanks,
Kevin
