pushrod tube dimensions
Folks, I need some help with dimensions. I have a styled B which needs a new pushrod tube. I have a home machine shop and want to make one if possible. Problem is I cannot seem to find any dimensions anywhere. I want to have the dimensions in advance to see if I have any material to make it from before tackling the project. If I dont have any tubing that'll work, I'll just bite the bullet and buy a new one but I would enjoy the shop time to make it from scratch. Any help would be appreciated. I can only find information on the non styled B's and my understanding is that they are not the same size.
Thank you in advance for your help.
Charlie
I made a pair of them a few years ago and the old ones are hanging on my shop wall. I will measure them tomorrow and post.
(quoted from post at 19:25:24 07/04/21) I made a pair of them a few years ago and the old ones are hanging on my shop wall. I will measure them tomorrow and post.
This is the measurements of the PR tubes that came out of my 1945 model B about 20 years ago, steel. The LG 4.165, ID .640, OD small end .725, large end .730 .
Here is how I made my PR tubes, I used 1/2 inch galvanized water pipe ( I would like to have used copper, brass, stainless steel but this is what I had) the ID was correct size no matching required. I faced each end to the correct length, I turned the OD between centers, turned each OD a couple of thousands oversized , turned the middle a couple of thousands undersized, chamfered the small end so it would start in. I tinned the machined surfaces with solder . Put a little sealer on them and pressed them in large end to the
front of tractor. Over 20 years CNC machining
HILL is spot on with the dimensions. If you were going to purchase material to make them from, 3/4 inch OD, 0.065 inch wall brass tubing would be the way to go.
Thank you Hill, That is exactly what I needed. I was thinking about using 1/2 brass water pipe. I knew it should be close but wanted to have
a more accurate measurement to determine if I even wanted to tackle it. Sounds like it should be a good project. Since I wont be tinning
mine, do you still suggest a couple thousand over?
Thank you and everyone else for your help. I tell all my tractor friends to check here for any question because you all have so much
experience and knowledge.
Charlie
