Put Put 6v frontmount
G6 at Snook, TX
I have a 6v frontmount that has an irregular ping after heating up. I have cleaned connections, changed the coil and bypassed the ignition switch. I have not done tune up since March and I used blue streak. It does not seem to lose power, but the miss is annoying.
Does this sound like the timing is a tad off? Points or condenser? Thermostat? I have adjusted the carburetor to 1 3/4 though this tractor runs real lean at about 1 1/4. (It has this with two different carburetors.)
Thanks.
lean can cause popping.. may sound like a ping.
very poor quality gas can cause sparkknock, commonly seen as ping. especially this new ethanol gas.. when the alcohol boils out and it sets.
richen her up a bit with the choke when she does it and see what happens.
soundguy
Okay,
I gave her a good spin in the 100 degree heat today. She heated up fast and resumed the irregular put put even after adjust carburetor and feathering the choke. FYI, the gas is about one month old and it has sea foam in it as a stabilizer.
I backed the main adjustment needle out to three or four turns from seated, but it did not make the requisite black smoke. I smelt the excess gas however. I settled the needle back to 1 1/4 from seated and it mowed under load.
I am at a loss on this. I am tempted to leave well enough alone, but that irregular ping sure sounds like a miss to me. I assume an improperly operating thermostat would cause it to overheat, diesel, and die. And I know that the timing on a frontmount is hard to mess up, but does this at all sound like a condenser malfunctioning?
Thanks for the insight and comments and advice.
Sounds like the problem I was having on my 49 8n. there was a miss I could not get rid of. After replacing everything electrical and cleaning carb that was new from previous owner. I measuered the jets and the main jet was to small. I drilled it out to 1/16" and put back together set main needle at 2 rounds out and now purs like a kitten. Might be worth a look and see if this could be your problem.
