Hey ya'll. I'm working on my tractor, so it must be Sunday...
I had to drop the pump for repairs. The ear (pivot point) where the lift control valves arm is pinned broke off on me. Rather than buy a new base, I J-B Welded it back on. So far, so good.
Upon re-assembly, it appears the PTO shaft has swole up durin it's short time out of the tractor. (Does the oil help keep the original diameter, or does sunlight make it grow? Sorry if I sound like a newbie.)
Anyways...I'm trying to stab the shaft back in and it won't go quite all the way in. It seems to go through the pump okay and then bottoms out. With a little wiggling (the shaft, that is) it comes back out as easily as when I removed it.
Should I go ahead and start pounding it with a 15-lb sledge until something breaks, mushrooms or explodes? Or...is there an easier way, such as rocking the tractor, working the clutch pedal, jacking with the PTO lever, etc?
In short...does anyone have a trick for easily installing the PTO shaft? (It's not mushroomed or twisted.)
Thanks for your help!
James
James
