Putting a c123 engine into a super a frame
Normie
I'm attempting to put an engine from a super c into a super a. Can I use the distributor that was in the super a engine? Also, will it be 6 volt positive ground? Thanks....
I think the distributors are the same. As for ground again depends on if your staying with 6 volts or going to 12 volts. Either way the coil get hooked up so what ever ground you use the distributor side is hook up same as it is grounded
