Bob Bancroft
- Location
- Aurora NY
It appears that pyrometers available require 12V. Does anyone know where I could get one which is totally mechanical, no electricity required, or if there is such a thing, or not?
ManyIt appears that pyrometers available require 12V. Does anyone know where I could get one which is totally mechanical, no electricity required, or if there is such a thing, or not?
To be permanently mounted in diesel engine exhaust.Many
What might the desired use be for?
Handheld?
Panel mount?
For vehicle exhaust?
For a furnace?
You want the probe to be measuring all of the time?
Thanks, I'll check it out. No confusion. Either a gauge requires 12V or it doesn't. EGT's my local supplier can provide have four wires, two for the probe, and two- 12V + and -. Backlighting is separate.Here is one, Pyrometer The lead sets and probes are sold separately. I chose this one because the link has a PDF manual named “Single EGT gauge manual” on the lower left. Not sure if this applies in your situation or not, but you may be having some confusion about installing one of these and the wiring required due to not understanding how they work. All pyrometers will have wire leads, that is how they work by measuring the electrical current produced as the probe is heated “thermoelectric” principle. Open that manual and you will see the lead circuits are a self contained circuits, no external power is used. The exception is if you want to backlight the dial.
Mark
