Been having problems with my 8N for a couple years. Used to run great. Does not have enough power to run my 5" mower. It is not electrical. It had the problem when it was 6 volt. Switched to 12V because I could never get the regulator and generator working. New wiring. Fried points and square coils. So I went to electronic ignition. New plugs, new copper plug wires, new cap, new rotor and new distributor. Still ran the same.
Been through 3 carbs and 2 fuel shutoffs. Still ran crappy.
I had checked the compression before I started all that and it seemed fine to me. Just checked it again today. All 4 cylinders would pump up to 110 cold on the 4th cycle (30, 60, 90 then 110).
The plugs always looked good to me, but when I pulled them again the other day, number 1 did not look so good (dark from bad combustion). 2 and 3 and 4 looked clean and good.
So I measured the valve clearances. My understanding is that COLD, Intake valves should be .12-.14 and Exhaust should be .14-.16 Here are my readings from 4 cylinder to 1 as if you were looking at the engine:
4 (E-.14 I-[color=red:2242102600].15[/color:2242102600]), 3 (I-.[color=red:2242102600]15[/color:2242102600] E-.16) 2 (E-.16 I-.12) 1 (I-.[color=red:2242102600]16[/color:2242102600] E-.[color=red:2242102600]18[/color:2242102600])
So cylinder 1 looks bad.
SO here is my Question. If the exhaust valve on #1 has a gap of .18, would that mean that the compression is good because it is not opening and since the cylinder can not rid itself of exhaust properly, it may have problem igniting since the cylinder is full of exhaust?
One of my symptoms was igniting in the exhaust pipe. Would this explain it?
Thanks, Obie
Thanks, Obie
