Question bout Magnetos
Farmallb
I was told tonight by a neighbor that he had always heard, that a mag either put out enough spark to start an engine, or it didnt work at all. It was one or the other, not haveing a mag with a weakened spark. Which way is it. I would have thought that a mag could have lost its strength somewhat.
They will get weak and lose their spark. During starting the impulse will spin the mag as fast or faster than operating speed so if the tractor starts it will probably run. This may be where his statement comes from. But sometimes the coils get hot and they will cut out. Usually dressing the points and a new condenser will get em going again. If that don't do it a new coil is next, then a remagnetizing of the magnet. With good wires and a little maintenance they are as reliable as any other ignition source.
Your neighbor is WRONG AS RAIN......
1) A mag can have a weak/impulse starting spark because the impulse spring is weak but once running it can have a normal very strong spark. Its common that a hand crank mag tractor can be a bear to start (due to a weak impulse spring) but if pull started it runs fine, because then the spring is out of the equation, its no longer winding up and tripping.
2) It can have BOTH a weak impulse starting spark AND a weak running spark due to perhaps bad points or coil etc.
3) Its possible for the rotor magnet to weaken with age which causes BOTH a weak start impulse spark andddddddd a weak running spark. A mag shop can recharge it if that happens.
4) The condition of the points is critical on a magneto. Often non sparking can be cured simply by buffing the points.
John T
One thing that hasn't been mentioned yet on your post is; With a magneto never use TVRS (carbon) plug wires. It will missfire if it fires at all.
Always use wire type plug wires when using a magneto. If you ever seen a mag run on a test bench you'll see a big difference in the consistency of the spark
Your neighbor is half right. A magneto with weak fire won't start your tractor. You need good blue fire. Dirty points are the first culprit I look for.
Weak magnets will cause weak spark. By touching them with a flatblade screwdriver you can tell if they have strong magetism. There's repair shops that can remagnetise them. Coils get weak too. Cleaning the points may help if the coil and magnets are ok. Hal
Well, I took the carb back to the rebuilder, and he saw that the float was at an angle, scrapeing the side. Brought it home. put it on. No go. Im going to take the mag to have it checked. The plugs, ive noted on another Cub I had, that if they gort soused by gas, they wouldnt work. im wondering now, if the spark was so lite that it wouldnt burn off the gas sufficently at startup
