Question for 2510paul
Question: you replaced the hydraulic pump on your JD 4320. What were th3 signs you needed a new pump? Low pressure? I have a 4020 powershift and the pressure drops off in 5th gear when going uphill, while under full load mowing hay. It seems to get worse as the tractor gets hotter too. I know the pump shaft bushing needs to be replaced.
Basically operation of frt hyd pump has no bearing on a Powershift trans. Powershift trans is supplied oil/pressure via trans pump. Does trans pump pressure get lower in any of the gears other than 5th gear?
Yes, what Tx Jim said.
Tim S. might want to respond.
My own experience is the pump just gets noisy. In one 4020 case I could really tell it in the vibration of the discharge line. On the 4320 it just got noisy but not so noisy I could not drive it. On a 2510 it sounded like the engine was literally coming apart. One of those times you shut the engine down ASAP. I also did a 3020, I am having trouble remembering on that one, I am thinking leaking and noisy. The 2510 and 3020 I rebuilt myself, the issues were obvious once I took them apart.
The 4020 and 4320 I got Re-Manufactured pumps from All States. From their catalog it is a little unclear if they are Re-built or Re-manufactured. The Sales guy confirmed Re-manufactured but he did not know the difference. Hmmm.
I have to admit in my case on the 4320 when I got in there I found the rubber bushings on the pump side were like new. On the dampener pully side they were bad, so bad they may have been down to metal on metal. So ya, I may have replaced a good pump but I was not going to put it all back together and try it. I am in there and anything I suspect or don't like the condition is getting replaced.
So, this is not your issue on the Power Shift. But for others, check both ends of the bushings carefully on the drive shaft to the pump.
Paul
When the tractor starts loosing power going uphill in 5th, I down shift into 3rd and the power starts
coming back up. It seems like the problem begins about 30 minutes into mowing, meaning the entire
tractor is now up to full temp. Does it less on a cooler evening. 5th is the worst. If I downshift into 4th
before I start going uphill, it doesn?t lose power. So naturally I make a point of down shifting into 4th. But,
that really isn?t solving the mechanical problem.
The pressures need to be checked in each gear. Does tractor lose ground speed in gears above 5th? Another possibility for tractor ground speed slowing is damper clutch is slipping.
