question for dieseltech
rustred
i am replacing throttle shaft seals on 560 rosa master pump . wanted to know if those 2 seals are specialty seals from you or case ih , i compered them to the o ring kit i have, not satisfied, the old ones are flat on outside but i am presuming thats from use.
You're right, they are flat over time. If the retainer ring is failing inside you will still have running issues until the pump is completely gone through, and light load advance set on the test stand..
