question for janicholson
Dave Cook
Jim, a couple weeks back you guided me through the cut out to regulator wiring conversion. The L lead from the regulator is now connected to the fuse holded and then the fuse holder to the light switch as I understood it. What now is the proper fuse? 15 amp? I'm still running a six volt system. Thanks.
15 amp is just fine, the lights are the only thing the fuse supplies. The ignition is also hooked to the terminal on the fuse, but is connected directly, not through the fuse. Jim
