question for Janicholson
53H
a few days ago, I was looking for help with plumbing the loader on my neighbors 350 utility. you offered 2 suggestions, the first to use stock valving, and the second to use a power beyond plate. Since he has already purchased the new valve for the loader, I would like to try the power beyond plate. my question is, was this a factory part, should i try the dealer, or some salvage yards, also, it should be noted, this tractor does not have power steering, if it makes any difference. thank you for your help, it is greatly appreciated.
Hi Capacity carryies those plates for '06 tractors and newer.I dont know about the older ones.Go ahead and try the dealer.If they cant get one,they should be able to steer you in the right direction.
The plate to provide additional hydraulic power could be called several names. The essential ingredient is control of the pilot valve and unloading system CaseIH should know what you are talking about, as should hydraulic dealers in construction and heavy equipment. Jim
