Question for Tx Jim and Tim S
jdpackfan
I am going through the syncro shifter assembly on my 2010 RU and I want to tighten up and replace the "commom" wear parts. I recall seeing a post a while back where you guys gave the main parts/bushings to tighten things up but I am having trouble finding it in the archieves. Can you help me?
Thanks! Gordon
You can find this stuff on JD parts .com... 2 T13554 bushing, 3 T13615 washer, 2 T13742 bushing, 2 34H314 pin,1 R52882 latch,1 R53247 pivot, this will tighten things up a bit.
I'll add this exploded photo to Tim's statement.
parts key # 6 is T13554
parts key #11 is T13742
parts key #14 is R53247
parts key #24 is R52882
24 was what fixed my 4010--Thanks to Tim for the info. I added a few other parts in there also.
Tim do you replace the pointers and springs on the shifters?I am refering to the two plugs next to the shift arms on the side of the transmission case.A Deere dealer told me to replace the pointers with a ball,retainer and spring found in the 4230 parts book.The pointers wear grooves in the shifters and the ball and spring fit the hole much better,sometimes we have added a washer or two to increase pressure.Seems to help alot.
Yes I have changed them over if it still had any latch problems, unfortunately a lot of times there is worn parts inside making it shift hard or not letting it stay in place..
