question on my to-30
James-TX
yesterday i cleaned my sediment bowl out on my to-30 when i wnet to turn the fuel back on nothing would come out when i took the tank off there was two big pan like peices of metal in the tank dont have a clue why its in there or what there for looked in my shop manual and didnt see anything about that......anybody know what they are?
I believe what is inside the tank is a baffle to help keep the fuel from splashing around to much. You said 2 pieces I was under the impression there was only 1. Maybe I learned something again today. This (these) baffles were just spot welded in there and many have become unwelded (is that a word?) Don't know more than that. Richard
well since they came unwelded is it gona hurt anything for them to stay like that.... i aint fixn to shell out 200 hundred bucks for a new one
Mine has been loose inside for over a year that I know of, I have no plans of having it repaired or buying a new one. The way I look at it the most that may happen, I suppose it could get lodged over the fuel outlet and not get fuel for a little bit. Without knowing exactly how they were made it is possible they could go over the outlet and nothing happen because the fuel may always be able to get under it. No problems yet as several say if it ain't broken don't fix it, well mine is broken and I still ain't planning on fixin it. Richard
There are two things going on here.
1) the plate in the tank is a splash baffle as pointed out and you surmised. It normally would be in place with the profile of the tank. These often come loose and are no big deal. Do not worry.
2) The second issue is the lack of fuel flowing into the glass filter after reassembling. This is also a normal condition. That seal is air tight. You are observing the trapped air captured in the now clean fuel filter. This bubble will clear out on its own as you run the engine and fuel is drawn down the line. If you want to get rid of it now then just loosen the glass bowl nut until the air seal is broken, the fuel will start to flow and fill the bowl and the air can now excape out the top. When the fuel starts to come out over the bowl, just tighten the nut again to make a good seal again.
Jeff
