Question on S/N??? on M
(quoted from post at 21:32:03 08/13/07) what does XL after the serial number stand for?
ook at it again. It's probably X1. Which means it's configured from the factory as a gasoline only tractor.
XL means you have 5000 foot pistons, 7 MPH 4th gear and low low gear.If you have one you my friend have a rare bird. The gears alone are worth what some tractors bring. Hang on to it and take good care of it.
I was thinking and am not sure about what I posted last night. Seems like that should have a number between the X and L. Like X1L. Just not sure, but my suffix chart does show L for those things I listed.
Thanks for your help where can u find a chart on the serial numbers?? that would be nice to have...thanks again for the help and info...
I suppose it could be mis-stamped. But,IH did not intentionally use the X codes unless it was followed by a number, then there could be a letter. X1L is as Georgeky says.
