Pat-CT
So I was unsure if my tractor was chargeing and the ampmeeter wasnt showing charge so i unpluged the battery with the lights on and engine running and they still we on, but dim so does that mean its charging at some rate at least at enough to keep the lights on?
no if the charging was ok the lites will be as bright as they normaly are, check the charging system and all ground cables, more than half of all charging system problems are caused by faulty grounds, all connections should be clean bright and tight, then have alt or generator bench tested if good may be voltage regulator
If you turned your lights on with the engine running then disconnected your battery all the lights would have burned out if your generator was charging.
When you disconnect your battery the voltage regulator senses a high resistance in the charging circuit and it will tell the generator to charge full force. I know I've done this before and it blew out all the lights. The charging circuit needs the battery or some sort of load to sense so it can tell the generator what rate to charge. Once the battery is disconnected the generator will try to overcome the high resistance, a generator has no limitation on how many volts it can put out.
Your generator is not charging if the lights did not burn out.
"Your generator is not charging if the lights did not burn out." Then why does he have any lights at all?
if you had engine idling ,the generator is working fine...you can test output with battery connected using a multimeter...high rpm should show around 13.8 volts when everything is working properly.
