I picked up a late model 8N at a very good deal. The owner was in the process of restoring it when he passed away. It was mostly disassembled when I got it. I have most of the parts, but I am missing various bolts, brackets, ect.
It was low on compression on #3 due to an egg shaped exhaust valve. I have installed a new valve and she's running good now.
Questions:
What is the lever on the right under the seat?
What type of bolt is used to attach the hood to the dash?
The governor area of the engine seems noisier than the rest of the engine. Is this normal?
Does anything go between the top of the radiator and the hood? Padding?
What size bolts do I need for the front bottom mounts for the hood? The ones under the radiator.
What is used to hold the battery in place?
Should there be anything between the fenders and the mounts on the axle? Is it just metal to metal?
Questions:
