OK, here is the other thing I found which requires a bit of background. When I first ordered the Overhaul kit from A&I everything came in one large box, but two of the cylinder sleeves had exited there smaller boxes and were allowed to bounce around inside the larger box. The sleeves were shipped with the pistons inside them which made them more heavy. I inspected them and sure enough one was cracked and one was bent at the flange. I mic'd the inside top of the bent one and found it off by 0.014" and you could feel the bend as you moved your fingers around the cirumferance using a rag...the bend felt flat.
So they replaced the two damaged sleeves, but I noticed they felt a bit lighter or felt a bit thinner than the last original sleeve that survived in the kit. The two replaced sleeves also fell into the cylinders about half way under their own weight much easier than the one left from the kit, eventhough the cylinders are within inside bore spec. The one from the kit wouldn't go into the cylinder very much at all. This was done as a test, I didn't freeze them yet. I figured they were just a bit thinner but would still work.
The kit sleeve weighs 18.50 oz, the two repacements weigh 17.85 oz. and 17.65 oz. so there was a difference.
I mic'd them and they met spec as far as roundness went, so I didn't bother anymore. I figured they would be OK.
Until I mic'd the flange...this is where I found an issue which caused the difference in measurement number I mentioned in one of my previous posts.
Let me splain:
In the above image in Fig 4 refers to the two replacement sleeves. As I would mic them, I put the mic against the wall of the sleeve and would tighten the mic. This is where I saw differnce in numbers becuase of the fillet corner in only the two replacement sleeves. The original sleeve as in fig. 3 has a square corner and I can keep the mic against the wall as I tighten the mic...giving me an acurate measurement of 0.150 all the way around the flange...no variations beyond 0.0005".
But the two replacement sleeves measured different because when I put the mic against the wall and would tighten, the mic would stop depending on where it would ride on the curve...that is why I saw differences in numbers. At the bottom of the curve the mic reads 0.155-0.156" and at the end of the curve if I let the mic ride it out would in fact read 0.150" all the way around the flange. So there is a difference with the replacement sleeves.
Here is my concern. If I freeze the sleeves and drop them in (see fig 1 and fig 2) will the replacement sleeves not go down all the way becuase the recess ledge's edge (which is square) inhibits them because of the fillet corner. Well, no big deal because they may protude out above the block face a bit which is what MasseyNut and WellWorn recommended anyway.
The concern is when these sleeve heat up and expand. What will happen then...will this push the sleeve up? or will it crack the flange off the sleeve wall?
When I pulled out my old sleeves from the engine, two showed cracked sleeves up around the flange. Was this caused by the recess being off like in the first picture, or because they were so old they began to wear down? Maybe they were original equipement. If you look at the first photo of the recess measurments, there is a logo on the old sleeves that read "WVY" but the W and V were connected...so it could be WVY, or VWY, or VVVY. I tried to google this to see if these were aftermarket sleeves or OE, and I couldn't find any info. There was also a logo drawing and patent number on these old sleeves.
So what do you all think about this? Sorry for the long post, but I'd like to get this right since it is a good deal of work and cost and I'd like the engine rebuilt properly.
If this all is overkill and I am overthinking it...please let me know...at least I will feel better about knowing I don't need to address these issues.
