Quick attach for a 236 loader
wpoff0209
I got a Massey Furguson 175 with a 236 loader and Im wondering if I can get a quick attach for the loader or what I need to look for, or if its possible
I have a JD 148 loader on a 4020 with pin on bucket. I got a MDS Sur-Lock quick attach and it works great. I have another tracker with skid steer quick attach, and I think the MDS is faster and easier to use.
If your bucket pins on, it might work for you.
If you are talking about a "skid steer quick attach" that allows you to change buckets and use other attachments, there are several companies that offer adapters. Some will even fabricate one for you, because I doubt one is made specifically for your loader as it is not a common loader.
Not all loaders are made the same. There may be another loader with similar dimensions that the adapter will fit yours. You need to know the dimensions, distance between arms at the bushing, distance to the outside of the arms at the bushing, pin diameter, and distance between pins center to center.
This is where I got mine. It wasn't cheap but it is well built and fits well. My only complaint is the levers won't stay up in the released position while I'm changing attachments, and it usually requires 2-3 times on and off the tractor. I haven't figured out how to keep them from flopping down yet.
https://hayspear.com/skid-steer-quick-hitch-adapters-attachments/skid-steer-quick-hitch-adapters/
Worksaver makes one.
A web search for ''quick attach adapter for Massey Ferguson 236 loader'' yields a number of different results.
