Quick Hitch compatible Plows
Are there any mounted three-bottom plows that will match up with a John Deere Cat 2 quick hitch?
Everything else I own will fit & it is aggravating to have to pull the quick hitch off, to put my plow on.
Thanks!!
Possibly Kverneland...
It will hitch but you may have a problem with the headstock. I find that mine often needs to be set some distance to the left and if the quick hitch can't adapt to that, you have a problem.
Rod
Devon Hubbard
Most lower 3pt pins are set at SAE specs which is 26" apart for Cat 1 & 32" apart for Cat 2. The usual quick hitch problem is top link pin on plow doesn't match q-hitch and has to be altered to match hitch.
