quick opinions needed
sgtbull
Looking at a Farmall Cub. Not sure of the year, but its an earlier one w/ the mesh screen grill and set screw front spindles.
Here"s what I was told:
New valves, guides, rings, pistons and bearings. Engine worked over by a NAPA shop.
New right rear tire. Left rear original, but good.
Rims are good
Has rear weights.
One new front tire, other weather cked, but sound
CORRECT, new carb
12 volt conv w/ new one wire alt.
Tin is straight but has some pitting
New manifold
Runs well.
Not a fast hitch tractor, but has rockshaft lift arm from touch control.
New clutch, pressure plate and tob.
No apparent cracks welds or brazings. Finals look good but have obvious oil leaks.
Missing air intake tube from breather to carb.
Battery box is junk.
Dist. ignition and looks like it needs rewired to be nice.
Grill bent but salvageable.
Owner wants $1000.00 delivered to my door.
Looks like a good deal to me, but want other opinions.
Sounds like a good deal, but I would want to drive it around first and listen to the trans for clunks, I have a Super A that I will not drive anymore due to clunks in the trans until I get time to work on it.
If you can see the NAPA invoice, drive it around to check the transmission and drive train, that is a bargain if you have a use for the Cub.
