How's the fuel filter & what's the condition of the fuel tank? Sounds like it could be starving for fuel.my international 434 quits after running about 1 hr, i have been able to use the plunger on the pump and get it refired. any suggestions
Is that gas or diesel?my international 434 quits after running about 1 hr, i have been able to use the plunger on the pump and get it refired. any suggestions
Isn't a 434 a diesel? thinking plunger pump for primingFeel the coil, if it’s hot replace it time ! That’s your problem
Never thought about the coil because every time it quits I just walk around tractor and use the plunger on the pump a couple of times and hit the key and it fires upFeel the coil, if it’s hot replace it time ! That’s your problem
Best to include the fuel type where the model used different fuel enginesit is a gas engine and the fuel tank is clean and a new filter has been installed . I will have to check the coil the next time, Thanks for the replies
Keep watch of your engine oil, the pump may be getting weak.Never thought about the coil because every time it quits I just walk around tractor and use the plunger on the pump a couple of times and hit the key and it fires up
Ah, I thought you may have had a diesel. My vote would also go to check the coil then.it is a gas engine and the fuel tank is clean and a new filter has been installed . I will have to check the coil the next time, Thanks for the replies
