Radiator and water pump source
drsevy
Successfully removed both the radiator and water pump form my"68 gas 2000
Am now looking for a good source for a replacement rad. and water pump.
thanks
check the parts site here from the site that sponsors this forum
soundguy
Radiator with Oil Cooler - For the following tractors with oil cooler, 3 cyl gas 158 CID or 158 CID Diesel: 2000, 3000, 4100, 4400 (1965 to 1975); 420, 532 with torque converter (1975 to 1981). Core is 18 inches tall and 16 inches wide. Oil cooler fittings on front side. Oil cooler can be plugged and not used if desired. (Part No: D8NN8005PA) $249.00 [Enlarge Picture]
Radiator - Core size (the finned part) is 18" wide 16" high 3 rows of tubes 7 fins per inch. Also replaces EONN8005MA15M, EONN8005KA15M, EONN8005LA15M, EONN8005MB15M, EONN8005MD15M, C7NN8005N. For 3-cylinder engines (1965 & newer) on: 2000, 2100, 2120, 2300, 2600, 2610, 3000, 3100, 3400, 3550, 3600, 3610, 3900, 3910, 4000, 4100, 4110, 4140, 4400, 4600, 4610. (Part No: C7NN8005H) $227.11 [Enlarge
Water Pump - For 2000, 3000, 4000, 5000, 7000 all 1965 and up; 2600, 3600, 4600, 5600, 6600, 7600 1975-111986. Water Pump with single pulley, back housing & gasket. 65016S (Part No: D8NN8501UC) $117.88 [Enlarge Picture]
Water Pump - Water pump with double groove pulley, less rear housing. For Models: 2000, 2310, 2600, 2610, 2810, 2910, 3000, 3600, 3610, 3910, 4000, 4100, 4110, 4600, 4610, 5000, 5110, 5600, 5610, 5700, 6600, 6610, 6700, 6710, 7000, 7600, 7610, 7700, 7710, (Part No: FAPN8A513DD) $90.08 [Enlarge Picture]
Water Pump - Water pump with single groove pulley, less rear housing. Pump has 516" & 716" dia. mounting holes and replaces earlier style pump with 516" & 38" dia. mounting holes. For 2000, 2310, 2600, 2610, 2810, 2910, 3000, 3230, 3430, 3600, 3610, 3910, 3930, 4000, 4100, 4110, 4130, 4600, 4610, 4630, 4830, 5000, 5030, 5110, 5600, 5610, 5700, 6600, 6610, 6700, 6710, 7000, 7600, 7610, 7700, 7710, (Part No: FAPN8A513GG) $52.87 [Enlarge
