Radiator cleaner?
jmohr
I have a Case L that I have to grease the water pump daily when I use it to keep it from leaking. My radiator is getting quite greasy. The engine is finally getting 80 years of rust and crud out of the water jackets and the cooling system. Would I benefit by adding dawn to the system with water before I drain it before I drain it before winter? I'm looking for any suggestions.
I work in engine testing and when an oil cooler leaks in the water system we drain the antifreeze and flush the heat x changers and engine with several gal of soap several times and then flush it with clean water,works everytime. Be sure to get the engine hot and drain while its warm!
