Radiator Removal Super M
My next task is to repair or replace the radiator on my Super M. I have all the body work off and it appears it bolts in from 2 bolts underneath. I assume the plug in the front of steering box removes as to get the shaft through the radiator. Do I disconnect the steering shaft somewhere and it pulls out the front?
I think this is the same as the H, which I have done a few times. You unscrew the big pipe plug, remove the bolt that holds the end of the U joint tight around the horizontal shaft and remove the woodruff key. Then all you have to do is turn the shaft and the worm gear will screw forward out through the hole where the pipe plug was removed.
Zach
