sandspider-HT
I have a small weep from my YM1600 radiator, but replacement radiators are expensive and thin on the ground over here. In the cupboard I found a bottle of Bars Leak - some sort of radiator stop leak chemical. I wouldn't want to use this on a modern engine (as it might clog up delicate bits that shouldn't be clogged up), but I'd guess there's not too much risk using it in an agricultural engine from the 1970s?!
Anyone used this type of thing on an old tractor, and did it work / block up the rad passages and make things worse? <E>:shock:</E>
