radiator support rod TEA20
doug larson
I am in need of the support rod for the radiator as it connects the top of the radiator to the engine. Does anybody have one available or know where I can find one?
Very easy to make yourself Doug. A bent piece of steel rod with holes in the end for split pins is all that it is . This shows one end , the other is just the same .
As Charles shows you it is very simple to make, just get a piece of round stock that will fit in the holes, heat and bend both ends, drill a small hole in both ends and install with cotter pins, or split pins if not in the U.S.
