Raked the yard today
Geo-TH,In
Been clearing trees around the orchard to make the orchard larger.
Putting the rake on the front forks makes it easy to see, easy on my neck, and rake floats over uneven lawn.
My tree guy tried attaching forks to his bobcat. Forks didn't float and would damage the grass.
The terramite is my back saver and not to mention it gives me something to do to combat cabin fever.
When I can't buy what I want, I make it.
The homemade forks are handy. Can't buy titan forks for this tractor.
What have you made that you can't buy??
Nice looking rig. Just found out from my Dr I've got issues in my back that'll need attention in the future. Hope to get it under control before I leave work in September. All those years of Class 8 diesel truck repair and cutting firewood for 22 years has caught up with me!! I tell young guys at work, watch your back!!
Have the problem is they didnt have all the tools and equipment for heavy repairs. You did what you had to do to get the job done.
Vito
Made a hydraulic bale spear out of an old battery operated fork lift.just disconnected the lift part then added 3-pt pins and welded on a 3rd link to it.took the forks off,welded a spear made from an old axle shaft. Worked great could lift a bale16-18 feet high.this was in the 90s couldnt afford to buy one then,cattle prices were terrible at the time plus I already had the old forklift and it was much tougher than store bought models
Couple friends have small 4 & 6 wheel models of V and straight line wheel rakes to rake up debris from their yards, only takes a Cub Cadet to pull them, a hydrostatic works best, Rake everything into windrows and then rake the windrows into piles and pick the piles up and load in carts or wagons and burn. Rakes up everything from thatch to grass clippings to seed pods and small twigs to bigger branches.
Do a search on STRONGWAY and YARD TOUGH and FIELD TOUGH.
My friends say they work great, cover large areas fast. A 6-wheel is about $500 at TRACTOR SUPPLY, Covers a 55 inch swath at 4-5 MPH.
I thought you would have snow over there., Here in northwest Ohio have the heaviest snow of the winter on the ground, cannot even see any ground let alone do and work like that.
