Random hydraulic questions
eod4647
Nothing Oliver specific, but they came to mind after driving my 880 the other day. Which fired right up after an almost five month nap.
Is there a need to have a hose connecting the hydraulic hoses when they are not being used? I have dual hydraulics, one of which is used with the three point, but the other isn't hooked up all the time.
My loader, using a PTO pump, has a hose connecting the unused valve (no grapple). Which made me think of this question.
The other question, any reason not to use quick disconnect couplers on the PTO pump hoses? I think it would be easier to remove the pump when mowing versus hanging it out of the way. Thanks.
Chris
I would not use quick couplers to a pto pump, I would think it would restrict to flow too much, also for the input line you would need a very large coupler, if your pump created suction it would collapse the hose. my input hose to the pump is 1 1/2 inch soft line. I have 3 loaders with pto pumps with pto extensions and a bar down to the drawbar to hold the pump from turning. I have the hoses long enough to pull the pump off and set on the drawbar if I need to.
Thanks for the input. It was a random thought, I just need to figure out a better way to hang it when I'm running the mower.
