Range transmission 5088
alfa2
Having a problem with range transmission on my 5088 yesterday while spreading manure I got back to pad stopped and was shifting to reverse and when I took it out of high into neutral I can't get it to go into any range I can go side to side in neutral but I can't get it to go into any range my question then is what did I do and how do I fix it thank you for any help I just got this tractor and like it a lot
There is a likelyhood that it is something in this linkage. (lets hope it is external) There are diagrams for
internal parts and shifter linkages/forks on this site as well. At the caseih.com websight find the parts store,
and search by model. Put IH 5088 in the search box. scroll to the second page to find the tractor. Jim
Diagram from caseih.com on line
(quoted from post at 04:29:42 04/12/19) Having a problem with range transmission on my 5088 yesterday while spreading manure I got back to pad stopped and was shifting to reverse and when I took it out of high into neutral I can't get it to go into any range I can go side to side in neutral but I can't get it to go into any range my question then is what did I do and how do I fix it thank you for any help I just got this tractor and like it a lot
Thank you we figured it out the park lock moved we got the instructions to adjust park lock from the dealer in Presque Isle got it adjusted properly and back to work. Thanks again
