Hey Ratface sounds like the only thing you have found is an issue with the idle mixture screw pull it out and see if they put a new seat in the original would have been .021 you can check this with the back of a drill bit some idle seats may have been replaced with a .033 seat. check your mixture screw length and diameter as well. This is similar to the TSX241 carb this is what your tractor came from the factory with .The TSX33 was a 9N carburetor there was also a reproduction 241 with problem of its own. Type this in on a Google search page DELETED! There were some SERVICE BULLETINS done over the years to tractors in your year range. Also SOME MIXING of parts from both carburetors was typical. Hears a sample DELETED! Here's A copy of a service bulletin DELETED!
I don't know if this will help uncover all of the service bulletin's on a 9n TSX33 carb or even were you can get them but maybe someone else can help you on that. The reason I would look for the S/B on the TSX33 is someone may have put parts back in that were deleted by the S/B or it may be missing an update.
I tried to post 3 links but it wont let me its from another web site
Email me and Ill send it to ya. [email protected]
I thought these links might help your problem I can send it to you so you can look thru it but of course the choice is yours.
I did find this
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=nboard&th=803438
Byron
It wont be today or tomorrow unless you see this before I leave.
I did find this
Byron
