Re: A mag timing.
Rusty wheel
With mark on flywheel lined up and number one piston tdc, the lug on the governor that meshes with the lug on the mag should be exactly horizontal. Maybe the flywheel is off a tooth. With number one piston on top, is the mark on the flywheel lined up? I had the same problem with an H and the advance inside the mag wasn't right.
I think I read in Duane Larsons material that an all fuel mag can be used easily for gas only if the governor is set off by one tooth to allow the mag to sit vertically when changing the timing from 35 deg to 25 deg btdc.
My A was set up this way, saves buying a new gas drive lug.
Sorry if it seems a bit sorted, just go to Duane's web site an look it up. There's a lot of good info there.
