HY-80
From Wikipedia, the free encyclopedia
Permit class USS Plunger on the building ways at Mare Island
HY-80 is a high-tensile, high yield strength, low alloy steel. It was developed for use in naval applications, specifically the development of pressure hulls for the US nuclear submarine program and is still currently used in many naval applications. It is valued for its strength to weight ratio.
The "HY" steels are designed to possess a high yield strength (strength in resisting permanent plastic deformation). HY-80 is accompanied by HY-100 and HY-130 with each of the 80, 100 and 130 referring to their yield strength in ksi (80,000 psi, 100,000 psi and 130,000 psi). HY-80 and HY-100 are both weldable grades; whereas, the HY-130 is generally considered unweldable. Modern steel manufacturing methods that can precisely control time/temperature during processing of HY steels has made the cost to manufacture more economical.[1] HY-80 is considered to have good corrosion resistance and has good formability to supplement being weldable.[1] Using HY-80 steel requires careful consideration of the welding processes, filler metal selection and joint design to account for microstructure changes, distortion and stress concentration.
Contents [hide]
1 Submarines
2 Metallurgy
2.1 Alloy content
2.1.1 Importance of key alloying elements
2.1.2 Trace elements
2.2 Characteristics
3 Weldability
3.1 Welding filler metal
3.2 Welding processes
3.3 Distortion and stress
4 Testing
5 References
Submarines[edit]
The need to develop improved steels was driven by a desire for deeper-diving submarines. To avoid detection by sonar, submarines ideally operate at least 100 metres below the Sonic Layer Depth.[2] World War II submarines operated at a total depth of rarely more than 100 metres. With the development of nuclear submarines, their new independence from the surface for an air supply for diesel engines meant that they could focus on hidden operation at depth, rather than operating largely as surface-cruising submersibles. The increased power of a nuclear reactor allowed their hulls to become larger and faster. Developments in sonar made them able to hunt effectively at depth, rather than relying on visual observations from periscope depth. All these factors drove a need for improved steels for stronger pressure hulls.
The strength of a submarine hull is not merely that of absolute strength, but rather yield strength.[3] As well as the obvious need for a hull strong enough not to be crushed at depth, the hundreds of dives over a submarine's lifetime mean that the fatigue life is also an important issue. To provide resistance to fatigue, the hull must be designed so that the steel always operates below its elastic limit; that is the stress applied by pressure is less than its yield stress. The HY- series steels were developed to provide a high yield stress, so allowing this.
US submarines post-WWII, both conventional and nuclear, had improved designs compared to the earlier Fleet submarines. Their steel was also improved and was the equivalent of "HY-42".[2] Boats of this construction included USS Nautilus, and the Skate-class, which were the first nuclear submarines, with the then-conventional hull shape. The later Skipjack class, although of the new Albacore 'teardrop' hull form, also used these earlier steels. Such boats had normal operating depths of some 700 feet (210 m), and a crush depth of 1,100 feet (340 m).
Although the operating depths of submarines are highly secret, their crush depth limits can be calculated approximately, solely from knowledge of the steel strength. With the stronger HY-80 steel, this depth increased to 1,800 feet (550 m)] and with HY-100 a depth of 2,250 feet (690 m).[2]
HY-80 steel was first used in 1953 for the construction of USS Albacore, a small diesel research submarine. Albacore tested its eponymous teardrop hull shape, which would form a pattern for the following US nuclear classes.
The first production submarines to use HY-80 steel were the Permit class. These reportedly had a normal operating depth of 1,300 feet, roughly two-thirds the crush depth limit imposed by the steel.[2] USS Thresher, the lead boat of this class, was lost in an accident in 1963. At the time, this unexplained accident raised much controversy about its cause and the new HY-80 steel used was looked at suspiciously, especially for theories about weld cracking having been the cause of the loss.[6][7][8]
HY-100 steel was introduced for the deeper diving Seawolf class, although two of the preceding HY-80 Los Angeles class, USS Albany (1987) and USS Topeka, had trialled HY-100 construction. USS Seawolf is officially claimed to have a normal operating depth of "greater than 800 feet". Based on the reported operating depth of Thresher, it may be assumed that the normal operating depth of Seawolf is roughly double the official figure.[2]
HY-100 too was dogged by problems of weld cracking. Seawolf's construction suffered setbacks in 1991 and an estimated 15% or two years' work on hull construction had to be abandoned.[6] Although later solved, these extra costs (and the post-Soviet peace dividend) were a factor in reducing the planned 29 Seawolf submarines to just three constructed.[9]
Metallurgy[edit]
HY-80 steel is a member of the low carbon, low alloy family of steels with nickel, chromium and molybdenum (Ni-Cr-Mo) as alloying elements and is hardenable. The weldability of the steel is good, though it does come with a set of challenges due to the carbon and alloy content.[10] The carbon content can range from 0.12 to 0.20 wt% with an overall alloy content of up to 8 wt%. It is also used extensively in military/navy applications with large thick plate sections that add to the potential weldability problems e.g. ease of heat treatment and residual stresses in thick plate. The primary objective during the development of the HY- grades of steel was to create a class of steels that provide excellent yield strength and overall toughness, which is accomplished in part by quenching and tempering. The steel is first heat treated at 900 degrees Celsius to austenitize the material before it is quenched. The rapid cooling of the quenching process produces a very hard microstructure in the form of martensite.[11] Martensite is not desirable and thus it is necessary for the material to be tempered at approximately 650 degrees Celsius to reduce the overall hardness and form tempered martensite/bainite.[11][12]
The final microstructure of the weldement will be directly related to the composition of the material and the thermal cycle(s) it has endured, which will vary across the base material, Heat Affected Zone (HAZ) and Fusion Zone (FZ). The microstructure of the material will directly correlate to the mechanical properties, weldability and service life/performance of the material/weldment. Alloying elements, weld procedures and weldment design all need to be coordinated and considered when looking to use HY-80 steel.
HY-80 and HY-100 are covered in the following US military specifications:
MIL S-16216[13]
MIL S-21952[14]
Alloy content[edit]
The alloy content will vary slightly according the thickness of the plate material. Thicker plate will be more restrictive in its compositional alloy ranges due to the added weldability challenges created by enhanced stress concentrations in connective joints.[15]
Importance of key alloying elements[edit]
Carbon ? Controls the peak hardness of the material and is an austenite stabiliser,[16] which is necessary for martensite formation. HY-80 is prone to the formation of martensite and martensite's peak hardness is dependent on its carbon content. HY-80 is a FCC material that allows carbon to more readily diffuse than in FCC materials such as austenitic stainless steel.
Nickel ? Adds to toughness and ductility to the HY-80 and is also an austenite stabilizer.
Manganese ? Cleans impurities in steels (most commonly used to tie up sulfur) and also forms oxides that are necessary for the nucleation of acicular ferrite. Acicular ferrite is desirable in HY-80 steels because it promotes excellent yield strength and toughness.[17]
Silicon ? Oxide former that serves to clean and provide nucleation points for acicular ferrite.
Chromium ? Is a ferrite stabilizer and can combine with carbon to form chromium carbides for increased strength of the material.
Trace elements[edit]
Antimony, tin and arsenic are potentially dangerous elements to have in the compositional makeup due to their ability to form eutectics and suppress local melting temperatures. This is an increasing problem with the increased used of scrap in the making of steel in the electric arc furnace (EAF) process.
The precise range of permitted alloy content varies slightly according to the thickness of the sheet. The figures here are for thicker sheets, 3 inches (76 mm) and over, which are the more restrictive compositions.
HY-80 HY-100
Alloying elements
Carbon 0.13?0.18% 0.14?0.20%
Manganese 0.10?0.40%
Phosphorus 0.015% max
Sulfur 0.008% max
Silicon 0.15?0.38%
Nickel 3.00?3.50%
Chromium 1.50?1.90%
Molybdenum 0.50?0.65%
Residual elements[ii]
Vanadium 0.03% max
Titanium 0.02% max
Copper 0.25% max
Trace elements[ii]
Antimony 0.025% max
Arsenic 0.025% max
Tin 0.030% max
A further steel, HY-130, also includes vanadium as an alloying element.[10] Welding of HY-130 is considered to be more restricted, as it is difficult to obtain filler materials that can provide comparable performance.[10]
Characteristics[edit]
Physical Properties of HY-80, HY-100, and HY-130 Steel[18]
HY-80 steel HY-100 steel HY-130 steel
Tensile yield strength 80 ksi
(550 MPa)
100 ksi
(690 MPa)
130 ksi
(900 MPa)
Hardness (Rockwell) C-21 C-25 C-30
Elastic Properties
Elastic modulus
{displaystyle E} E (GPa)
207
Poisson's Ratio
{displaystyle nu } nu
.30
Shear modulus
{displaystyle G=E/2(1+nu )} G = E / 2 (1 + nu) (GPa)
79
Bulk modulus
{displaystyle K=E/3(1-2nu )} K = E / 3 (1 - 2nu) (GPa)
172
Thermal Properties
Density
{displaystyle rho } rho (kg/m3)
7746 7748 7885
Conductivity
{displaystyle k} k (W/mK)
34 34 27
Specific heat
{displaystyle c_{p}} c_{p} (J/kgK)
502 502 489
Diffusivity
{displaystyle k/rho c_{p}} k / rho c_p (m2/s)
.000009 .000009 .000007
Coefficient of expansion (vol.)
{displaystyle alpha } alpha (K−1)
.000011 .000014 .000013
Melting point
{displaystyle T_{melt}} T_{melt} (K)
1793 1793 1793
Weldability[edit]
HY-80 steel can be welded without incident provided proper precautions are taken to avoid potential weldability issues. The fact that HY-80 is a hardenable steel raises concerns over the formation of untempered martensite in both the Fusion Zone (FZ) and the heat affected zone (HAZ).[11] The process of welding can create steep temperature gradients and rapid cooling that are necessary for the formation of untempered martensite, so precautions must be taken to avoid this. Further complicating the weldability issue is the general application of HY-80 steels in thick plate or large weldments for naval use. These thick plates, large weldments and rigorous service environment all pose additional risks due to both intrinsic and extrinsic stress concentration at the weld joint.[19]
HIC or HAC - hydrogen induced or hydrogen assisted cracking is a real weldability concern that must be addressed in HY-80 steels. Hydrogen embrittlement is a high risk under all conditions for HY-80 and falls into zone 3 for the AWS method.[20] HAC/HIC can occur in either the Fusion Zone or the Heat Affected Zone.[21] As mentioned previously the HAZ and FZ are both susceptible to the formation of martensite and thus are at risk for HAC/HIC. The Fusion Zone HIC/HAC can be addressed with the use of a proper filler metal, while the HAZ HIC/HAC must be addressed with preheat and weld procedures. Low hydrogen practice is always recommended when welding on HY-80 steels.[11]
It is not possible to autogenous weld HY-80 due to the formation of untempered martensite.[11] Use of filler metals is required to introduce alloying materials that serve to form oxides that promote the nucleation of acicular ferrite.[11] The HAZ is still a concern that must be addressed with proper preheat and weld procedures to control the cooling rates. Slow cooling rates can be as detrimental and rapid cooling rates in the HAZ. Rapid cooling will form untempered martensite; however, very slow cooling rates caused by high preheat or a combination of preheat and high heat input from the weld procedures can create a very brittle martensite due to high carbon concentrations that form in the HAZ.[11]
Preheating should be considered to allow diffusible hydrogen to diffuse and to reduce the cooling temperature gradient.[22] The slower cooling rate will reduce the likelihood of martensite formation. If the preheat temperature is not high enough the cooling temperature gradient will be too steep and it will create brittle welds. [22] Multipass welds require a minimum and maximum inter-pass temperature with the purpose to maintain yield strength and to prevent cracking.[22] The preheat and inter-pass temperatures will depend on the thickness of the material.
Welding filler metal[edit]
Generally, HY-80 is welded with an AWS ER100S-1 welding wire. The ER100S-1 has a lower Carbon and Nickel content to assist in the dilutive effect during welding discussed previously.[23] An important function of the filler metal is to nucleate acicular ferrite. Acicular ferrite is formed with the presence of oxides and the composition of the filler metal can increase the formation of these critical nucleation sites.[24]
Welding processes[edit]
The selection of the welding process can have a significant impact on the areas affected by welding. The heat input can alter the microstructure in HAZ and the fusion zone alike and weld metal/HAZ toughness is a key consideration/requirement for HY-80 weldments. It is important to consider the totality of the weldment when selecting a process because thick plate generally requires multi-pass welds and additional passes can alter previously deposited weld metal. Different methods (SMAW, GMAW, SAW) can have a significant influence of the fracture toughness of the material.[1] SAW as an example can temper previous weld passes due to its generally high heat input characteristics. The detailed hardness profiles of HY-80 weldments varies with different processes (gradients vary dramatically), but the peak values for hardness remains constant among the different processes.[1] This holds true for both HAZ and weld metal.
Distortion and stress[edit]
Given the compositional differences between the base material and the composite zone of the weld it is reasonable to expect that there will be potential Distortion due to non-uniform expansion and contraction. This mechanical effect can cause residual stresses that can lead to a variety of failures immediately after the weld or in service failures when put under load. In HY-80 steels the level of distortion is proportional to the level of weld heat input, the higher the heat input the higher levels of distortion. HY-80 has been found to have less in-plane weld shrinkage and less out-of-plane distortion than the common ABS Grade DH-36.[25]
Testing[edit]
The testing of HY-80 steel can be divided into the categories of destructive and non-destructive evaluation. A variety of destructive tests from Charpy V-notch to explosion bulge can be performed. Destructive testing is not practical for inspecting completed weldments prior to being placed in service; therefore, NDE is preferred for this case. Non-destructive evaluation includes many techniques or methods: visual inspection, X-ray, ultrasonic inspection, magnetic particle inspection and eddy-current inspection.
The ultimate tensile strength of these steels is considered secondary to their yield strength. Where this is required to meet a particular value, it is specified for each order.
Notch toughness is a measure of tear resistance, a steel's ability to resist further tearing from a pre-existing notch. It is usually evaluated as the tear-yield ratio, the ratio of tear resistance to yield strength.[26][27][28][29]
Wrought HY-80 steels are produced by, amongst others, ArcelorMittal in the USA,[30][31] and castings in HY-80 by Goodwin Steel Castings in the UK.[32]
References[edit]
Jump up ^ USS Tullibee, 730 dives during her time in commission.[4] USS Torsk, a diesel training submarine, made 11,884 dives.[5]
^ Jump up to: a b Elements not added deliberately
^ Jump up to: a b c d Yayla, P (Summer 2007). "Effects of Welding Processes on the Mechanical Properties of HY80 Steel Weldments". Materials & Design. 28: 1898?1906 ? via Elsevier Science Direct.
^ Jump up to: a b c d e "Run Silent, Run Deep". Military Analysis Network. Federation of American Scientists. 8 December 1998.
Jump up ^ Heller, Captain S. R. Jr.; Fioriti, Ivo; Vasta, John (February 1965). "An Evaluation of HY-80 Steel as a Structural Material for Submarines". Naval Engineers Journal. Wiley. pp. 29?44. doi:10.1111/j.1559-3584.1965.tb05644.x.
Jump up ^ "USS Tullibee ? History".
Jump up ^ "History of USS Torsk (SS-423)". usstorsk.org.
^ Jump up to: a b Lyn Bixby (8 September 1991). "Subs' Hull Problems Resurfacing". Hartford Courant.
Jump up ^ Rockwell, Theodore (2002). The Rickover Effect. iUniverse. p. 316. ISBN 0-595-25270-2.
Jump up ^ Polmar, Norman (2004). The Death of the USS Thresher. Globe Pequot. pp. 1?2. ISBN 0-7627-9613-8.
Jump up ^ "HY-80 STEEL FABRICATION IN SUBMARINE CONSTRUCTION" (PDF). Bu. Ships. 21?22 March 1960.
^ Jump up to: a b c Flax, R.W.; Keith, R.E.; Randall, M.D. (1971). "Welding the HY Steels" (PDF). American Society for testing and Materials (ASTM). ISBN 0-8031-0073-6. ASTM Special Technical Publication 494.
^ Jump up to: a b c d e f g Roepke, C (August 2009). "Hybrid Laser Arc Welding of HY-80 Steel" (PDF). Supplement to Weld. J. 88: 159?167.
Jump up ^ Chae, D (September 2001). "Failure Behavior of Heat-Affected Zones within HSLA-100 and HY-100 Steel Weldments". Metall. Mater. Trans. 32A: 2001?2229.
Jump up ^ "Military Specification: Steel Plate, Alloy, Structural, High Yield Strength (HY-8O and HY-1OO)" (PDF). 19 June 1987. MIL-S-16216.
Jump up ^ "Military Specification: Steel (HY-80 and HY-100) Bars, Alloy" (PDF). 5 June 2003. MIL S-21952.
Jump up ^ Lippold, John (2015). Welding Metallurgy and Weldability. United States of America: Wiley. pp. 288?300. ISBN 978-1-118-23070-1.
Jump up ^ Lippold (2015), p. 226.
Jump up ^ Kou, Sindo (2003). Welding Metallurgy. United States of America: Wiley-Interscience. pp. 74?84. ISBN 978-0-471-43491-7.
Jump up ^ Holmquist, T.J (September 1987). "Strength and Fracture Characteristics of HY-80, HY-100, and HY-130 Steels Subjected to Various Strains, Strain Rates, Temperatures, and Pressures" (PDF). AD-A233 061.
Jump up ^ Lippold (2015), pp. 288-297.
Jump up ^ ASM Metals Handbook. Volume 6. United States of America: ASM International. 1993. pp. 184?188. ISBN 0-87170-377-7.
Jump up ^ Lippold (2015), pp. 213-262.
^ Jump up to: a b c Patella, Gregory (December 2014). "A Review of Welding Processes, Mechanical Properties, and Weldability of HY-80 Castings" (PDF). Graduate Program Rensselaer Polytechnic Institute. pp. 13?14.
Jump up ^ Washington Alloy. "Technical Data Sheets" (PDF).
Jump up ^ Kou (2003), pp. 66?97.
Jump up ^ Yang, YP (November 2014). "Material Strength Effect on Weld Shrinkage and Distortion". Weld. J. 93: 421s?430s.
Jump up ^ Kaufman, John Gilbert (2001). Fracture Resistance of Aluminum Alloys: Notch Toughness, Tear Resistance. ASM International. p. 38. ISBN 978-0-87170-732-1.
Jump up ^ "Properties of HY-100 Steel for Naval Construction" (PDF).
Jump up ^ "Tensile Properties of HY80 Steel Welds Containing Defects Correlated With Ultrasonic And Radiographic Evaluation" (PDF). April 1972.
Jump up ^ "Alloy Steels HY80".
Jump up ^ "HY 80 / 100 (MIL-S-16216)". American Alloy Steel.
Jump up ^ "Armor: Steels for National Defense" (PDF). ArcelorMittal USA.
Jump up ^ "GSC Defence supply materials" (PDF). Goodwin Steel Castings Ltd.
[hide] v t e
US submarine classes after 1945
Nuclear-powered ballistic missile submarines - SSBN
George Washington class Ethan Allen class Lafayette class James Madison class Benjamin Franklin class Ohio class Columbia class
Nuclear-powered cruise missile submarines - SSGN
Halibut Ohio class
