Re: Carburetor Flooding
jh105
Is float valve seat screwed down tight? Sometimes new one is a bit longer than original and has to engage dirty/rusty threads further down the hole. Doesn?t allow fiber washer to compress and seal.
About as tight as I can get it without stripping the brass. I don t have a screwdriver wide enough to twist it so I ve been using a knife blade
According to the books with the top of the carb inverted the float is suppose to be level with the top. That doesn't always work. I have a jeep that was flooding with the float set textbook correct but I adjusted it to where it as elevated a little and it quit flooding.
(quoted from post at 15:09:58 05/25/19) Gas fouled, running too rich.
Where are you on this?
Is the carb back on, still dripping when sitting not running?
I have not yet put the carb back on. I have to split the tractor tomorrow because it s seizing somewhere. I think (and hope) it s in the clutch area cause all my bearings are getting oil and the valves are fine.
