Re: Clutch Issues Belarus 825
used red MN
Location
Coon Rapids, MN
Hello HB welcome to YT! Did you take it to the dealer to have them diagnose a problem with the tractor or did you take it
there and tell them I want the clutch replaced? If they diagnosed it and recommended the clutch replacement as a fix to a
problem you have more leverage to have them take on part of the cost of opening it up a second time. More details on
the actual problem would be helpful. I assume by ..floating charges.. you mean what is invested so far towards fixing the
problem.
just to throw in two cents and ask small details.. I gather the transmission gears are still turning when
the clutch pedal is pressed down, did the pilot bearing get replaced by the dealer[ not mentioned in
post], to grind gears, the input shaft is turning like a tight pilot bearing will cause[ BTDT] or maybe
the synchronizing assembly is at fault? a later item to consider for now.
and not being a smart a.., but is it possible the PTO pedal is being operated and not the main clutch
pedal?
If you a first time Belarus owner, its possible, so if the PTO is in gear[ not ground speed] on the 400
series machine the PTO is pulled back for live PTO, and turning as the tractor sits still/in neutral and
the PTO pedal[ to the left of the main clutch pedal] is operated is there any gear grinding engaging the
PTO ? does it stop turning?
The PTO operation will tell us if/that section of the clutch is working to narrow down the problem.
hope it helps.
morning: Got to thinking on this and how about this thought...there should be a cover either top side or underneath that allows access to the clutch for inspection purposes.
with someone pushing the pedals, you should see the clutch plates moving a set distance, and they move where you can see, but if the operating levers are not adjusted evenly, one third of the clutch plates may still be engaged, hence the turning of the transmission input shaft, when you idle/shutdown to shift that remaining friction is overcome.
Rotate the clutch with a barring tool[ fuel lever off] and check that all the levers are adjusted to move the same amount of travel and the plates are seen to have a bit of travel, this will also put even loading on your throw-out bearing
Check and adjust both PTO and main clutch levers while in there.
Hope it helps
