Re: danuser blade
Either model the G-16 or the later G-16A Case Danuser with hook up and work fine I have several of both versions I use on my farm, this one is the EH version or also known as a G-16 model I have both 6' and 8' units,
cnt
I appreciate the quick reply. I bought a ber plow and it will hook up but you have to remove a lift arm to do it. I have been told it's made for the bigger eagle hitch tractors. Thanks again I just want to make sure it would work.
The BER was designed and used with the SC/DC tractors. I had a VAC mounted years ago, it was a 2/14 but
lighter, with the trip or release mechanism. I don't recall the designation of it
No, that blade is too big for the VAC, where is it and how much do they want for it?? (<; If they don't want an arm and a leg for it jump on it with both feet. There is no better blade made than the Case/Danuser back blade IMHO. Also Danuser still supports a lot of parts for these blades. I have the DAnuser parts list for this blade if you need a copy. My mail is open.
Jim
