Re: Farmall M rear wheel width
The Data book shows the bare weight of a M around 5,000 lbs with no wheel weights or loaded tires, in agreement with your response.
Your strong response leads me to believe that the rear tires are not loaded. If they are loaded, you would need to add additional weight based on the tire size.
13.6x38 tire- 57 gallons,610 lbs per tire
14.9x38 tire- 67 gallons, 717 lbs per tire.
Thus if the tires are loaded, based on tire size, you would need to account for an additional 1200 to 1400 lbs. Good luck hauling.
