Re: IH B275 tractor
Hi, don’t forget to keep the kingpins and thrust bearings greased as
well. Check the steering box for oil/grease and keep it adjusted. A lot
of smallish things but they all contribute.
DavidP, South Wales
Hi, been there done that on a 434 with 1501 loader, the other hint is never try to steer unless the tractor is moving.
Re add PS, find a wrecked B414,434,444,384 with the PS and it should fit the B275.
About a month ago I was at the son of a farmer that my Dad used to do custom corn chopping for back in the 1960s and he still has his father's B414D that his father bought new in 1962.
I was looking at it and I noticed he had made a PS kit for it by using a regular double acting hydraulic cylinder with a bracket that went on the left side of the clutch housing where the loader mount holes
are located and the another bracket on the steering drag link. He had added a splitter into the hydraulic high pressure line but I could not see what he had used for the steering wheel to connect too.
I would assume it is something from a log skidder as this man runs a shop that services and repairs log skidders.
