Re: JD 4010 hydraulics
Thanks for update. I remember way back in time the 1st JD tractor I was diagnosing for hyd problems & discovered the closed center center conversion plug inner seal was blown causing hyd's to stop operating correctly.
Any original 4010 pump is probably worn out twice,, be sure you are using a "Closed" center valve, this can be proved by heading the return line into a bucket,, when the valve is centered there should be no flow into the bucket.
