Re: JD300 motor project
finally was able to get the reverser assembly out, what a pain in the carpel tunnel. i had to take the pins out of the loader frame and jack the frame up out of the way to get the clutch shaft out of the way to be able to remove the aluminum support cover to access this assembly
it kind of looks okay to me not knowing anything about it
got a few rub / wear marks but if it dose not need replaced at this time i would rather not,
disks are only about 30$ x 6 required so not terrible but the piston is like another 300$
i took the rockshaft cover off to inspect and everything in there looks really good, and seemed fine ...
i have just about everything and ready to start putting it back together this is the last assembly at this time and the parts cost is really adding up .....
thanks
bob
