RE: need help Identifying a/c model
Gary Souza
I have a small ac we just picked up,have not found serial number yet.Its a small three wheel tractor.It has a small four cylinder engine.I found engine plate that has some numbers I can read 1262412 and 3 1/8 X 4 any help would be welcomed Thanks
Sound most likely a model C, but without a picture its hard to tell. Look right around the shifter for the SN. The preceding letter/s should tell you the model.
I would also guess either a C or CA. Either model with a single front wheel would be the least common version by numbers. Both tractor models were offered as 2-wheel tricycles that are the most common, adjustable wide fronts next most common, & SFW with only a few hundred ever built. Kip
I looked at pictures of the model C looks to be differant than the one we have,ours has about 4inch channel frame rails
Gary, what size are the rear tires, and how many speeds on the transmission??
Does this tractor have an AC emblem on the tinwork?
Is this a gas or diesel?
Does the plate that you refer to state Made in USA?
This should be enough questions for now, but there may be a few more asked??
Sounds like you may have your self an RC same engine as the B/C but the frame more like a WC/WD. The B/C/CA all used the engine as part of the tractor frame but the RC/WC/WF/WD/ and WD45 use a channel iron frame that the engine sort of sit down in
Except that that bore and stroke (3 1/8 X 4)comes out to 157 cid.. The model CE Allis engine is 125 cid , has a 3 3/8 X 3 1/2 bore and stroke, and does not bear an id plate..
(quoted from post at 17:23:58 02/19/10) Except that that bore and stroke (3 1/8 X 4) 123 cid. The model CE Allis engine is 125 cid , has a 3 3/8 X 3 1/2 bore and stroke, and does not bear an id plate..
