Re: Restoration Question
Stephen Newell
You might consider restoring the decal. You might make a stencil and replace the missing data with paint. If you have a good picture of a complete decal it would help. You could enlarge the picture to life
size and print it on computer paper. Then use an exacto knife to cut out the letters. From there spray the back side of the stencil with a light coat of spray adhesive and it will stick on the surface you want
like contact paper. Then use a paint made for plastic and apply multiple light coats of paint. A wet coat the paint will run under the stencil where a light coat almost like overspray will work fine.
If you take a picture of the decal and go to a place that does vinyl wraps or decals they should be able to reproduce it,we have a local place called Cherry signs that can do that
kind of work and I'm sure there are others that do that also.
Thanks for the reply. That is very interesting. That old tractor went a long ways from where she sold. Makes you wonder how it got all the way to New Mexico.
Search " decal paper" . They make paper that works on an inkjet printer. Just print and apply to your project. I have used it and works very well, bought mine on ebay. joe
