well got an update for my 8n not starting. after my new carburetor issue I rebuilt the one that was on the tractor and I still the darn thing still wont start. so I fiqure I have exhausted everything on the fuel flow issue since I am now fouling out the plugs. I have gas all the way to the spark plugs now. moved to compression.
compression was not what I would of like to of seen but should be workable. (not to temp for obvious reasons) pressures are recorded as below
cyl 1 85
cyl 2 82
cyl 3 76
cyl 4 74
moved on to the electrical .the following is what all I have checked and how.
first I checked power to the coil. there was no power going to the coil. I hot wired the coil strait from the battery to eliminate any wiring or switch issues that may have been causing this issue. started seeing what I had going to the plugs. was good white spark but seemed a little sporadic so I looked at the points to see if they were sparking correctly. again seemed to be a little inconsistent checking with the power on to the coil and moving the points by hand. finally I checked the coil wire from coil had the same inconsistencies when I opened the points by hand. changed out the coil. rechecked as previous now everything became consistant and good white sparks.
I do want to note that when I removed the coil that was on there
had the power in going to the negative post of the coil. when I installed the new one I put it back power in to positive post and negative to the distributor. everything looked good so I went back to the issue of no power to the coil. I found that when I replaced the coil I was now getting power through the switch through the resistor all the way to the coil. best I can figure is some sort of short in the coil itself. any ways tried to start it again.
now the tractor will fire off run for about 10-15 seconds(not long enough to do any adjusting to the carb) and flood itself out.
does anyone have an idea on where to go from here? this is really wearing me out. any advise is always is greatly appreciated!!
cyl 1 85
cyl 2 82
cyl 3 76
cyl 4 74
