re-torque head bolts
1974vette
I replaced the head gasket on a 54 super w4 mccormick a while back. I want to re-torque the head and have seen on this form to do that after the tractor has been run for a while. the question is do you do this while the tractor has run and is still hot or letting it cool is ok. thanks in advance and I enjoy reading all the post on this forum. I have learned a lot
When I do them I usually run it until it is up to temperature, shut it down and start re-torque after it has cooled down. I think the idea is to run it through a heat up/cool down cycle before re-torque. I don't think the engine needs to be "Hot" during the re-torque.
Don't forget to re-set the valve lash after the re-torque.
It's not that critical, I have done it cold on 5 tractors, no leaks. What you do want to do is reset the valve tappets.
You do a retorque with the engine to operating temp and this is done just as soon as you get them running the FIRST TIME . Is this important YES will the head bolt torque change when when HOT yes . You will find that the bolts towards the center of the head will be looser then the ones on the ft. and back of the head .
I did my H after it cooled off and everything shrank back a bit. And then I did it again after 100 hours. And again. It took several times before the bolts all stayed tight.
Greg
In its service manuals IH defines hot as any temp over 70 degrees. They also state not to adjust valves on a recently run hot engine because the quality of work will suffer because of the hot engine.
